Sunroof Quit
Old Apr 17, 2014 | 08:33 PM
jalodge's Avatar
Default Sunroof Quit
Today when I tried to open the sunroofs, I pushed the button and opened the front perfectly fine. When I went to open the rear, that is when the problem occurred. I pressed the button a loud almost grinding noise came from what I think was the ECU and then neither sunroof responds with the buttons. When I press the button the ECU does not even make the clicking noise that it usually does when a switch is pressed, leading me to believe it is the ECU. Does anyone have any suggestions or can confirm this before I tear the headliner down.
Old Apr 17, 2014 | 10:25 PM
acamato's Avatar
Check the fuse for the sunroofs. Fuse 12. See page 6.1 in the rave elect library.
Old Apr 18, 2014 | 08:07 AM
jalodge's Avatar
Where do I get the RAVE elect library?
Old Apr 18, 2014 | 08:36 AM
dusty1's Avatar
is it not under your workshop manual?
dunno if download differs from my disk, though
Old Apr 18, 2014 | 08:45 AM
jalodge's Avatar
No mine doesn't have it but I have the fuse numbers in the owner's manual.
Old Apr 18, 2014 | 08:51 AM
dusty1's Avatar
12 and 29 in the passenger box, what are you looking for? i have it open
Old Apr 18, 2014 | 09:00 AM
jamestfl's Avatar
it's my understanding that the sunroofs also close manually with a 4mm allen hex, behind the rectangular plastic tabs near the sunroof switches.
Old Apr 18, 2014 | 09:05 AM
dusty1's Avatar
true that^ some overseas came with a manual crank only
Old Apr 18, 2014 | 10:30 AM
jalodge's Avatar
Yes mine does have this option but I would have to drop the whole headliner to do this while I think I can get to the ECU through the switch panel. I am trying to avoid taking the headliner down since I just had it out 3 days ago to fix the leaky sunroof drains.
Old Apr 18, 2014 | 10:31 AM
jalodge's Avatar
Thanks, I will check those fuses.
