Sunroof reset and fog lamps
Old Jun 24, 2011 | 10:09 AM
Gerard's Avatar
Default Sunroof reset and fog lamps
Hi..any help will be greatly appreciated.
1.) I read somewhere about resetting sunroof motors. I have not opened my sunroof in over a year due to leaks and I will be working on it now but for some reason the motor will not work. How do i reset the motor. Front and Rear. Thanks.
2.) My fog lamps were working until last week. The switch inside does not turn on with the small red indicator light on the switch not going on. My bulbs are new...any tips on the switch..could it be a fuse?? If a fuse, nothing else is out except my fog lamps.
Thanks for the help.
Gerard
Chicago
2000 Disco 11
Old Jun 24, 2011 | 06:09 PM
mwindth's Avatar
I don't know about re-setting the motors...but you can remove the square access button near the switch and use a 4mm Allen wrench to open manually.
Your second problem sounds like a fuse...
Old Jun 24, 2011 | 06:51 PM
Urban Panzer's Avatar
fogs wont work without headlights on.
Old Jun 24, 2011 | 08:49 PM
buick215's Avatar
and they won't work with the high beams on either.
Old Jun 25, 2011 | 07:59 AM
coors's Avatar
Check the ground for the fog lights. Maybe, the ground's point of contact on the metal frame may have rusted out.
Old Jun 28, 2011 | 10:49 AM
Gerard's Avatar
Thanks for all the tips. I know about fog lamps not working when brights are on and head lamps have to be one for fog lamps to work. So, that is out of the equation.
I will check the fuse and the ground. Where would I find the ground wire for the fog lamps.
Thanks for the advice on the hex tool to manually open the sunroofs.
Gerard
rambo
Oct 17, 2013 10:13 PM
trp34
May 21, 2012 07:02 PM
Baboo
Mar 17, 2009 01:18 AM
DV57
Jun 28, 2007 11:55 AM
A12LR3
Nov 12, 2006 11:20 AM
