Supercharge Disco?
Hi
I was on ebay looking for cheap land rover and i happned to stumble on a SUPERCHARGE LAND ROVER. And i just want to know where do you get that supercharger kit?, if so name some area and online site and also is it bad for the engine?
http://cgi.ebay.com/ebaymotors/WOW-S...QQcmdZViewItem
Thx
Thx
The previous attempts at fitting an after-market supercharger to the Land Rover V-8 have mostly resulted in premature engine failure. The reason comes down to boost distribution not being even among the cylinders when "blowing" through the stock intake manifold. A couple cylinders would end up with an overall "lean" mixture that would cause a mechanical failure. So ---there really isn't any "kit" available that I've ever seen. Every one of these installs has been a "one-off", with the exception of a southern California custom shop that turned out a few dozen supercharged Range Rovers. From what we have seen up here in Northern California, as we have worked on a few of them--- they all lost their engines, and the owners went back to a stock configured powerplant.
So whoever ends up with that eBay Disco is playing in the "experimental" area.
Regards,
Geoman
www.eurotekapg.com
Regards,
Geoman
www.eurotekapg.com
There is a guy on cardomain.com with one. Hes running 6 psi I believe...
And yes, there are kits:
http://www.capa.com.au/kits_landrover.htm
S.
S.
DonnaC
Apr 13, 2010 10:28 PM
nextelsucks
Appearance & Camping Set Ups
May 18, 2008 08:58 PM
nextelsucks
Mar 28, 2008 09:25 PM
