Superlock / Actuator issue... '04 Disco
Hey everyone,
I know the #1 reply to posts are always to read previous threads but after sitting online for 3 days going over everything im still kinda lost.
I'm having an issue with my 04 Disco. It's currently stuck in superlock mode and I can get in and out with the drivers door and my key, and when I hit the unlock on my key fob and the central button inside I can here the motors in the door move but they stay locked. About a month ago, my front passenger door stopped unlocking by the buttons and I had to reach over and pull the handle.
So like I've said I've read posts and I've tried everything (holding the key in unlock for 3/5 seconds, checking all the fuses, etc). I went to the dealership and they told my I have to replace all of the door latches, which just seems totally ridiculous.
From what I've been reading I think I could just pop the inertia switch in the BCU and replace the front passenger actuator. Does this sound like the right solution?
Hey everyone,
Im not sure if it happend to me or similar case. But here it goes. There is a part in the door handle like a 4inch nail with a star at the end. This tiggers the electronics in the door once you turn the key. If that nail looking shaft brakes you can only lock driver side door with key but you can lock the rest through the center lock on dash or with remote key. If that is the same problem, i can guide you with the fix or just replace the shaft.
caneraiser
12-30-2021 09:39 PM
