Suspension spacers?
RE: Suspension spacers?
ORIGINAL: Disco Mike
So what size and brand tire would make you go to a 15" wheel?
Also, even if you're not lifting put on some disconnects on the front swaybar at least (EE is taking them over from Slickrock at the moment so they should be available again soon) and if you're spring in the back you'll want to remove or fit some kind of disconnect, I'm looking at some JKS "quick" disconnects since they split in the middle since in the rear the end pin is obstructed on one side. Even with stock suspension and mud tires with the swaybars disconnected you'll see a significant improvement off-road. Just that change make my truck go from tipping in deep holes to running through them fairly smoothly.
newBrover
11-05-2007 01:35 AM
