suspension update.
I have a 2000 disco II in mint condition. I am going to put knew shocks in, the terra firma medium load with all knew mounting hardware and the terra firma steering stabilizer. Should I change out the springs to knew as well or are the originals ok. . No lift. Are going with the new shocks enough. Never use it for offroading just a daily driver since purchased knew. Thanks for all the advice. This forum is the most amazing place for info.
Joe
Joe
Only you would know, or an expert... Depends on the miles on your truck. At some point the original springs start sagging. If you put new shocks on sagged springs you'll just ruin the shocks prematurely as they will have to work harder.
A measurement taken from the center of the wheel to the top of the wheel well arch will tell you if your springs have sagged. If I recall correctly stock should be 19" +/- .5
Joe
Joe
Here are the factory Heights from the RAVE
FRONT
Nominal height from hub centre to wheel arch (not
liner)*
500 ± 15 mm (19.7 ± 0.6 in)
Front road spring colour codes:
⇒ V8 LHS Pink/orange
⇒ V8 RHS - LHD Pink/orange
⇒ V8 RHS - RHD White/purple
⇒ Td5 LHS White/purple
⇒ Td5 RHS - LHD White/purple
⇒ Td5 RHS - RHD White/purple
Rear road spring colour codes:
5 seat, LHS Purple
5 seat, RHS - LHD Purple
5 seat, RHS - RHD Purple/purple
7 seat, LHS - LHD Grey/blue
7 seat, LHS - RHD Grey/green
7 seat, RHS - LHD Grey/blue
7 seat, RHS - RHD Grey/white
Bump stop height (top of bump stop to axle bracket) 44.5 mm (1.75 in)
liner)*
5 seat, LHS Purple
REAR
liner):*
⇒ Coil spring 483 ± 15 mm (19.0 ± 0.6 in)
⇒ Air spring 473 ± 15 mm (18.6 ± 0.6 in)
Road spring colour code Purple (all models)
Bump stop height (top of bump stop to axle bracket):
⇒ Coil spring 71.5 mm (2.8 in)
⇒ Air spring 61.5 mm (2.4 in)
liner):*
I have a 2000 Disco II in mint condition. I'm experiencing suspension issues. When I hit a bump when driving my rear end drops. I engage the button for the rear end riser and then it will fill up and go back to its normal position. Does anyone have any recommendations?
Or, if you want to keep your air ride, you need to find the leak and replace parts.
But, since the bags pump up, and pump back up after deflating, I would think that the compressor is ok.
Possibly a check valve, or small hole in the bag or a line that opens up as the suspension travels.
At least my response bumps this back up in the New Posts.
Someone more familiar with your problem will be along soon enough.
If the suspension drops, it's supposed to automatically raise back to the regular ride height. Having to manually reinflate means that something is probably up with the ride height sensors, along with whatever is causing the deflation in the first place.
Diagnosis and replacement parts could get costly. You might want to look into a coil conversion -- it's pretty straightforward and doesn't affect ride comfort much at all. (I converted my '99 before I decided to junk it.)
greg409
08-17-2012 12:09 PM
fastrx7man
01-28-2012 12:49 PM
