Svs
Svs
I went to the Falcon site and noticed there are 2 items for this. The new seals for 40 and the seals with switch for 130. If I use plan B from the sticky guide do I still need the switch kit? If I am bypassing the switch itself does anyone know if the full kit includes anything I would need besides what comes with just the new seals and clips?
When doing the option "B" mod, you are not bypassing the switch, just changing where the switch gets its power and where it grounds. First off, are you sure the switch is the cause of the Amigos? Have you scanned the codes?
I gambled on my Amigo cause, and didn't check for codes first. Once I got the switch removed, I tested it via Josh's writeup, and it tested bad, so I knew at least that was a cause of the Amigos. I replaced the defective switch, modified with the option "B" wiring to prevent a potential problem in the future, and also replaced the seals, even though they were dry as a bone.
