Did the Option B SVS Fix
Old Nov 25, 2011 | 09:47 PM
coors's Avatar
Default Did the Option B SVS Fix
After an unsuccessful attempt last weekend I decided to disconnect/remove the ABS module. I tried and tried to remove the (3) 4mm screws that hold the SVS cover plate on with the unit in place - it was a pain in the ****. To all you who were able to remove the cover plate without disconnecting the brake lines and removing the abs module, I applaud you. You have incredible patients.
Actually, I was quite surprised, removing/replacing the ABS module was not all that bad. Didn't have to activate the ABS pump to cycle the air, I had my old man pump the brake pedal and I cracked the bleeder's (starting at the passenger's rear, driver's rear, passenger front, driver's front). By the time, I got to the passenger front line almost all the air was purged from the system and we had a normal brake pedal again!
When I was sure all the air was out of the system (we went through a bottle and a half of brake fluid) I set the transfer case to Low, activated the HDC and let it do it's thing down my driveway. HDC worked fine. Then, I took it out on the road, got her up to 55-60 mph (T-case in high) and did a brake-stand. Stopped on a dime, especially with my new rotors and pads. NO MORE THREE AMIGOS!!!
If anyone wants to tackle this repair and has questions, feel free to shoot me a PM. I'll see if I can help.
I wanted to add these quick side notes. I followed this to a "T".
If you disconnected brake lines... Bleed the brakes. You can use the traditional method with a helper following this sequence: Rear Right, Rear Left, Front Right, Front left. Brake pedal may still feel spongy. Go for a test drive and try to get the ABS and TC to kick on. Find a good incline to test HDC or on a flat ground, accelerate and let off the pedal and HDC should kick in, slowing you down. You must actuate these functions in order to get the trapped air out during the final bleed. Re- bleed the brakes. It is very important to do this last step after you successfully activate TC/HDC/ABS so that the trapped air in the modulator is expelled.
Now, I can install my new CDL shifter! Thanks for the shifter Hilltoppersx!
Old Nov 26, 2011 | 06:31 AM
hilltoppersx's Avatar
Glad u got the shuttle valves done. One box you can tick. just take your time and label all the differnt screws when taking out the console. You have any questions let me know. Take pictures of how it comes apart if you need to. like I told you before, when you put it back together use sheet metal screws where the rivets are currently. In case you need to get in there when a drill is not handy. After the cdl is in you will be ready to wheel with us!
Old Nov 26, 2011 | 08:34 AM
Always do the electrical ground repair at the same time cause it usually always acts up also.
Old Nov 27, 2011 | 11:13 AM
coors's Avatar
done and done.
Old Nov 27, 2011 | 11:47 AM
Rovin4life's Avatar
actually the best way to bleed the abs modulator is at the modulator. works every time. you dont have to get underneath the vehicle. just start with one then the others and do it four times with each different one on top as you start.
works for all modulators regardless of vehicle.
you just need someone to press the brake pedal when you do it.
Old Nov 27, 2011 | 01:31 PM
Can you better explain this?
Old Nov 28, 2011 | 12:04 AM
coors's Avatar
I think he is saying you can bleed the lines at the modulator. Simply, crack and bleed all four lines at the modulator.
Old Nov 28, 2011 | 06:37 AM
the d2's are not like the d1's.. you have to bleed the brakes and the modulator to make sure that all air is purged from the system. if you are out on the trails you can get away with just bleeding the brakes but if you want to make sure the brake pedal isn't mushy one bit then you need to bleed the modulator as well.
Old Nov 28, 2011 | 08:29 PM
Got it, thank you.
jycsalas
Jan 8, 2025 07:38 PM
boudini
Sep 23, 2020 06:10 AM
cipher982
Jul 3, 2013 06:03 PM
kenk
May 26, 2012 08:11 AM
texmbr
Dec 14, 2010 08:26 AM
