SVS replaced on ABS mod, now complete failure.
I replaced the entire SVS switch this morning without a great deal of difficulty using this guide: ABS Mod - LAND ROVER CLUB V.I.
Did great! Wired everything back up and went for a test drive in the yard, it wasn't long before I realize that I couldn't brake at all, and that the pedal (when attempting to brake) sank all the way to the floor. I'm guessing that I missed the requirement for brake bleeding with this procedure? That is my question, I took the ABS modulator out of my car, put it back in, and now, it won't work unless the brakes are bled?
Thanks, please be gentle with my noobiness, I'm learning.
-Matt
EDIT: Just found the place in the guide that says "if you disconnected any brake lines, the brakes MUST be bled."
-Matt
LA_Disco2
10-24-2023 10:43 PM
SkymonkeyONE
05-08-2013 12:29 PM
