SVS replaced on ABS mod, now complete failure.
Old Jul 20, 2011 | 01:28 PM
Intellius's Avatar
Default SVS replaced on ABS mod, now complete failure.
I replaced the entire SVS switch this morning without a great deal of difficulty using this guide: ABS Mod - LAND ROVER CLUB V.I.
Did great! Wired everything back up and went for a test drive in the yard, it wasn't long before I realize that I couldn't brake at all, and that the pedal (when attempting to brake) sank all the way to the floor. I'm guessing that I missed the requirement for brake bleeding with this procedure? That is my question, I took the ABS modulator out of my car, put it back in, and now, it won't work unless the brakes are bled?
Thanks, please be gentle with my noobiness, I'm learning.
-Matt
EDIT: Just found the place in the guide that says "if you disconnected any brake lines, the brakes MUST be bled."
Old Jul 20, 2011 | 02:11 PM
lordmorpheus's Avatar
Lol, you beat me to it. Check my post on how I bled the brakes in the shuttle valve seal replacement sticky.
Old Jul 20, 2011 | 02:58 PM
bosshogt's Avatar
Yeah, unfortunately you have to bleed the brakes on each of the 4 wheels. It should only take about an hour more. 4 Jack stands helps too. Good time to rotate your tires.
jycsalas
Jan 8, 2025 07:38 PM
LA_Disco2
Oct 24, 2023 10:43 PM
Wayne
Oct 2, 2020 12:10 PM
SkymonkeyONE
May 8, 2013 12:29 PM
yuenie
Dec 17, 2009 04:29 PM
