SWAP Rear A/C 03 D2 to 04 D2
Any advice or experiences transferring Rear A/C to another "non-rear A/C" D2?
Target for the transfer is my restored 04 D2 Sport.
I picked up a junker 03 SE-7 for the rear jumper seats and, it also has rear A/C. Paid $500.
Anyone done this? Please advise..
Much appreciated
My concern are the A/C "lines".. Wondering if they were installed in a non-accessible way at factory assembly..
AJ in Tucson Arizona
Much appreciated
The rear a/c evaporator is above the rear wheel, and the fan/ductwork is behind the driver’s side jump seat. There are lines from the back evaporator to somewhere up front, because it is fed freon off the same condenser. They are accessible from under the vehicle, so don’t worry about that.
You’ll need to wire up the rear controller as well, and possibly use an obdII tool to modify the BCU. You’ll need the headliner with the vents/controls as well.
I’d imagine studying the RAVE manual is your best course of action, but this will not be easy. Not impossible either.
Are you swapping in Jump Seats?
A/C Rear Swap D2
Yes, rear jumper seat swap as well, thanks because complete hardware is there to do so.
I do have two extra rear jumper seats from ebay I'll post for sale once Project is complete in a couple months.
Lucked out with this junk 03 se7..
Any recommendations regarding aftermarket stock or rather, not excessively huge front bumper replacement appreciated. Solid metal, no crap plastic like original..
Thank you
AJ Rigoli Tucson Arizona
Thank you
You'll also have to install the seatbelt and all the jump seat mount points if you're planning on using the rear jumps. The rear "cabinetry" is also particular to the 7-seat models, with special latch points and cutouts.
And then if anyone is injured while riding in one of them and you get in a crash, you're probably on the hook for liability since the vehicle didn't come with them installed from the factory.
PS: Read the RAVE manual carefully first.
