Swivel oil
Old Jan 28, 2009 | 09:20 PM
DiscoRom's Avatar
Default Swivel oil
I had my swivel oil replaced with grease. I might be a bit paranoid but I thick they didnt put enough grease in the swivel housing.
The ball feels dry. Since its not leaking before the replacement can I just add Royal Purple gear oil in the swivel housing?
Old Jan 28, 2009 | 09:34 PM
Default RE: Swivel oil
20 pumps per side with your manual grease gun every 6 months is all you need.
You can add a few ouces of gear lube if you want, but for the last 30,000 miles that is all I do, grease every 6 months.
Old Jan 28, 2009 | 09:42 PM
DiscoRom's Avatar
Thanks Spike fro the quick reply, which bring me to my next question.
I will have the truck serviced for lubrication.
I am assuming that they havent serviced a Disco before.
Where are the spots that need to be lubricated?
Also any type of grease will do right?
Thanks
Old Jan 28, 2009 | 09:50 PM
The only spots that need attention are the u-joints, nothing else needs anything other than being checked, like the front and rear diffs and the t-case fluid levels checked.
Grease the u-joints at every oil change.
Old Jan 28, 2009 | 10:00 PM
DiscoRom's Avatar
Saw this link.
http://www.landroverclub.net/Club/HT...e_greasing.htm
Is this the same procedure to what should be done to the D1?
Old Jan 28, 2009 | 10:13 PM
llPANCHOll's Avatar
Swivel Oil..
Can sombody elaborate on what and where this is???
Is it the Ball on inboard side of the Hub on the front wheels??
ORIGINAL: DiscoRom
Saw this link.
Thanks alot for that link..
I would have done it all wrong..
I worked on a Wheat farm and had to grease the implements and tractor every day..
The guy who oned the farm was very insistant that I only put 2 pumps every fitting every day, or I would blow the seals..
I would have just put in enough to push out a little of the black stuff, and not all of it if I hadnt seen this link..
Thanks again..
This forum is a great resource,
Only trick is.. Read every Thread!!
Old Jan 29, 2009 | 05:42 PM
Yes it is the big shiny ball looking thingy on the inboard side on the front wheels.
There is a square nut on the top front of it, 1/2"? open end wrench to remove it.
Some have a drain plug at the bottom, dont worry about this if you have one.
The swivel ***** were supposed to be filled with gear lube, but it leaked, so they went with a gear lube/grease mixture, then all grease.
Use the same grease that you use on everything else in your swivel *****.
Old Jan 29, 2009 | 08:36 PM
Rover has long since changed their recommondation on swivel oil suggesting you use their new grease swivel grease, 1 packet per side for better wear protection and little or no leaking.
Old Jan 29, 2009 | 08:41 PM
http://www.roverparts.com/Parts/STC3435S.cfm
Old Jan 29, 2009 | 08:49 PM
llPANCHOll's Avatar
Methinks thats just grease in a Fancy Package..
