swivel pin housing oil
I am about to replace the axle shafts in 96 D1. Rave says to drain and later replace the oil at the swivel pin housing with recommended oil. What oil is recommended?
TIA,
TIA,
at some point in time Land Rover changed the required fluid from gear lube to a grease....part # stc3435g or stc3435 at Atlantic British (roverparts.com) the grease is less likely to leak out
http://www.roverparts.com/Parts/STC3435.cfm
This is what you need, it is also called "00" grease, you can get it at your Snapper dealer, they use it in the differentials on Snapper lawnmowers.
It is just a really thin grease.
cosmickites
Defender
Sep 7, 2019 04:51 AM
