swooshing sound under passenger seat?
Old Mar 15, 2006 | 05:01 PM
lisalisa's Avatar
Default swooshing sound under passenger seat?
Does anyone know what the swooshing water sound when turning is by passenger seat. Discovery II Series?
Old May 3, 2006 | 02:23 AM
gjk8's Avatar
3rd Gear
Default RE: swooshing sound under passenger seat?
I had the problem too. As it turned out, the swooshing sound was caused by a low coolant level. Once I had the leak fixed, the problem went away.
Keep an eye on the level as I nearly overheated in stopped traffic heading to the dealer.
Old May 6, 2006 | 12:12 PM
rinmud's Avatar
she probably has a seven seater and yes low coolant or an air pocket in the lines
Old May 6, 2006 | 02:29 PM
xadamx's Avatar
i just had my 03 disco II serviced for the same problem and it turns out that the coolant level was low due to a leak from one of the main coolant gaskets. it was not expensive, and was a quick fix.
Old May 7, 2006 | 11:11 PM
ORIGINAL: lisalisa
If you want to e-mail me off line I will walk you thru bleeding the air from the coolant.
Mike
Mavic19
Aug 27, 2014 02:42 PM
bfamous
Mar 17, 2014 04:16 PM
dillhole
May 31, 2008 06:40 AM
don_r6
May 15, 2007 08:45 AM
