Symptoms/no start/stall
Old Aug 15, 2018 | 01:07 PM
CollieRover's Avatar
Default Symptoms/no start/stall
I just got the D2 started, but it was acting as if it had no gas. Turning over fine. It seems like Crank Position Sensor issue.
in addition, I had a random stall a couple weeks back, started right up after, has acted normally since.
I had a leaking elbow pipe after geadgaskets and was getting some misfires around that time, since replacement, no codes.
what I am wondering is if it is possible that the hot coolant from the leaking elbow pipe has fouled the camshaft position sensor.
Has anyone had a camshaft position sensor go bad?
Old Aug 15, 2018 | 01:58 PM
Sixpack577's Avatar
I doubt the coolant could really get in to the cam position sensor from an exterior drip above it.
Old Aug 15, 2018 | 04:58 PM
I believe you're right, also if you have a bad CPS the truck will not crank correct?
I think it has to do with the injectors/fuel line, and lucky me, I get to take my intake manifold off to redo the drivers side head gasket!
Old Aug 15, 2018 | 08:04 PM
Sixpack577's Avatar
I can't say for sure, but I think a D2 will run(misfiring)with a bad cps, as some other vehicles will. And of course sometimes they just die altogether, and it won't run at all.
Old Aug 15, 2018 | 08:07 PM
Sixpack577's Avatar
Look at it this way,
when...if, we ever completely fix our D2's,
we should be Land Rover Mechanics by then!
Old Aug 16, 2018 | 04:56 AM
The Deputy's Avatar
The engine will crank over with bad Crank Position Sensor....normally...just won't start...unless intermittent.
​​​​​​​ Brian.
Old Aug 16, 2018 | 07:57 AM
Brian.
It sounds like my new CPS was not really an upgrade. We'll see. I have to redo the LH HG so I will get a good look at the fuel line and INjectors, sort of thinking one is allowing air in, or the fuel rail is not connected well enough.
Old Aug 16, 2018 | 07:59 AM
This is what I keep telling myself! a 4.8 with upgraded Cam is sounding better and better every day! But I think I dicked up the torquing process on the LH side. How? I have no idea, but the truck has not overheated, the head was professionally checked, and the block is Turner so I believe the surface is flat, but am going to try and rent a tool to check.
Old Aug 16, 2018 | 08:02 AM
Sixpack577's Avatar
What are you trying to check?
Old Aug 16, 2018 | 08:08 AM
If the fuel is being delivered to the inectors/Motor, somehow rail is emptying due to a leak, and causing delayed start. If it looks normal I may swap out the CPS while the intake manifold is off. It's a standard motor products which I have not had issues with their coilpacks.
