Synthetic vs regular gear oil and ......
I'm looking at the service manual right now Mike, there is no service interval except for the trans filter to be changed, under warranty, at 30,000 miles by the dealer for free and then it is "lifetime" after that.
Nothing else, other than engine coolant, brake fluid and trans fluid and engine oil needs to be changed per LR.
I am NOT saying that I agree with that, I am just saying that is what LR says.
Wrong Approach: If you use, say Valvoline gear oil it'd cost $15-$20 to replace. If you never replace it and you have to buy one differential in 10 years and get a used one for like $100 you save a couple bucks and a bunch on labor/time on 15 fluid changes. Multiply that by two and the benefits become clear.
Can you copy and paste the page for me to see?
I have searched the entire RAVE and it is not in there.
Full syn gear oil will last at least 100,000 miles, so if it came with full syn from the factory, it would not need to be changed until the 100k mark.
Again, not saying I agree with that, I'm just saying...
Oh that wasn't a dig at you; just a left field comment. I know where you are coming from. I was searching high and low for the recommended service interval for the differentials (front, center, and back) so I could service them accordingly and could not find it.
I use cheap gear lube and check it after I wade for water ingress.
If there is water I change it, if not I dont worry about it.
I made the mistake when I first got my truck to use full syn gear oil, I went wading, got water in the diffs, drained out $100 of gear oil two weeks after putting it in.
I change it every two years now, I never get water in it any more as I fixed the leak, but I cannot see the benefit of spending that much money on gear oil.
I literally went page by page through the whole RAVE manual, including the DII NAS owners manual and it says nothing about gear oil, power steering, etc.
It tells you how to change the gear oil and top off the power steering, but no service interval.
The dealer will tell you that you need to change it every "X" miles because they make money off of services.
I do agree that it needs to be changed at regular intervals, but what those are I do not know and would like to see so that I can have that knowledge too because I think it would be good to know.
Yes, you are arguing, and for those new people on this site looking for correct information, you are misleading them.
Here is a link to the service schedules , by Rover,
http://www.landroverresource.com/docs/D2_03-04.pdf
From now on, make sure of your replies and statements so I don't have to correct you again.
