System lean codes
Old Nov 13, 2007 | 05:07 PM
trevorr's Avatar
7th Gear
Default System lean codes
My 99 Disco II 111k milesis showing these codes
P0171 - system too lean (bank 1)
P0174 - system too lean (bank 2)
Could this be the 02 sensors going bad or a result of the previous owner not using premium fuel?
The codes reappearwithin 50miles or soof being cleared and driven and almost always after it has set overnight.
Thank you for any advice.
Old Nov 13, 2007 | 05:20 PM
Default RE: System lean codes
What are you running for an air filter?
Old Nov 13, 2007 | 06:08 PM
trevorr's Avatar
7th Gear
Hi Mike,
I've only owned it for a week and I haven't changed it. But I checked and it issome kind oforange paper filter.
Old Nov 13, 2007 | 06:11 PM
Good, at least it is not a K&N which will usually kill your MAF which will throw 2 lean codes and one 4th gear out of ratio code.
You may still need a new MAF, let me know if your exhaust starts to smell or if the truck starts having shifting problems for either 4th. gear or lock up.
Old Nov 13, 2007 | 06:28 PM
trevorr's Avatar
7th Gear
I noticed when I checked the filter it looks like the MAF has been replaced. There is a bosch installed now. Could this be the problem?
Old Nov 13, 2007 | 06:40 PM
willstevens's Avatar
So does anyone have a recommendation fora brand of air filter?
Old Nov 13, 2007 | 07:07 PM
ORIGINAL: trevorr
Bosch is what is supposed to be on there. If you can find a good experienced Rover mechanic you be able to test it, but it will probably cost you as much to just plug and play a new one.
Wait though until you see if any more issues show up.
Old Nov 13, 2007 | 07:19 PM
trevorr's Avatar
7th Gear
What would the exhaust smell like with the MAF going out? And it does shift funny sometimes. What would itshift like with the MAF going out?
Thanks again
Old Nov 13, 2007 | 08:05 PM
The exhaust just has an off smell and the tranny will feel like it is hunting for 4th gear and lock up, kind of uncertain shifting.
Old Nov 14, 2007 | 10:44 PM
trevorr's Avatar
7th Gear
The "incorrect 3rd gear ratio" code showed up today. Is this a sign of the MAF being bad?
Also, I am getting a little moisture dripping from the tailpipe whenthe vehicle isfirst started but not when its warmed up and a little smoke that also goes awayonce it is warmed up.
Has anyone else experienced this?
