t/cases questions
Old Feb 27, 2017 | 09:00 AM
dwatterson1's Avatar
Default t/cases questions
I am unable to use my low gear in the transfer case due to some modifications. what is the difference in using the low range on the transmission.
Old Feb 27, 2017 | 09:35 AM
OffroadFrance's Avatar
Low range is about 1/5th of the speed and 3x the torque. Generally used for offroading in mud, sand or on rocks and also excellent for very steep inclines with loose or muddy ground. If you're an offroader you defo need a low range.
Paul Grant
Nov 2, 2015 05:52 AM
missler
Apr 3, 2014 06:19 PM
Paul Grant
Dec 12, 2012 04:33 PM
Paul Grant
Mar 30, 2012 10:29 AM
hunter
Feb 8, 2011 11:20 PM
