Tach and Battery Light
there were a few incidents when my tach doesn't move at all after a cold start. but it always worked fine again after a few minutes. when this happens, the battery indicator on my dash lights up as well and turns off at the same time as the tach 're-functions'. this only happened a few times before yesterday. but from last night and today, its always happening when i start it up. and the last time, it didn't go away. (the battery is less than a year old by the way).
and this happened after i finally fixed my idling problems!
any ideas?
any ideas?
RE: Tach and Battery Light
Did you have the serpentine belt off recently? I've heard of the alternator slipping if the belt is routed wrong since the wrong routing significantly reduces the contact patch on the alt. pulley. It would be more likely to slip when cold-the belt would get more grip as it heats up...
J P Cook
06-04-2014 09:40 AM
arrkerr
12-14-2005 10:06 AM
