Tail Light Issues
Old Jun 17, 2011 | 11:30 PM
willrok13's Avatar
Default Tail Light Issues
Hi Guys,
I noticed tonight that my left (drivers side) tail light doesn't seem to be working (running light works fine). When I depress the brake pedal, the right (passenger side) lights up but not the left. About a month ago I replaced the same bulb when I noticed my brake lights were out (running lights still worked though). I inspected the bulb before I replaced it last time and it had burned out. I haven't looked at the bulb tonight but I suspect its the same thing.
I performed a search and read that "if the sidelight goes out when you depress the brake pedal, you have a bad ground."
Where are the ground points for the tail lights? Inside the housing? Also, does anyone have experience with this? Thanks.
Old Jun 18, 2011 | 05:41 PM
Remove the whole light assembly and check for water ingress and corrosion.
It is a common problem for that taillight to leak and fill with water and corrode the circuit board.
Old Jun 20, 2011 | 07:59 AM
willrok13's Avatar
Thanks for the help spike. I looked at the light this weekend and didnt find anything out of the ordinary. The bulb had not blown and everything seemed okay. On another note, I mentioned in another post that my rear hatch will not unlock. I have narrowed that down to the actuator rather than a lubrication issue. Could these two issues be connected somehow (dim brake light and door actuator)? I poked around the truck looking for ground points and didn't find any. Could a short in the actuator case this? Any ideas before I order a new actuator for the rear hatch?
RoverGuyZ
Jan 11, 2026 01:00 PM
rambo
Oct 17, 2013 10:13 PM
Kalel
Mar 29, 2012 08:31 PM
primey
Oct 5, 2011 10:06 PM
garover
Mar 21, 2005 11:21 AM
