Tail lights and signals not working
Old Nov 17, 2009 | 08:05 PM
kumbhani123's Avatar
Default Tail lights and signals not working
Can't seem to figure out what's wrong. I visually checked the fuses under the steering column, they looked good (#33). I removed the bulbs from the assembly and switched them with the brake light bulb and nope, still no go.
Any ideas? This is a 2000 Discovery II
Thanks
Old Nov 18, 2009 | 03:21 AM
Rover Chris's Avatar
Check ALL the fuses (under hood and dash) don't need to check the airbag fuses, then I would clean all the grounds in the back. If that does not resolve your problems and your brake lights are working, you may want to look at the headlight switch. I am not sure how a D2 headlight switch is wired but it could be a possibility. Maybe even get a multimeter and start working your way back to find where the broken link is in the chain.
Old Nov 18, 2009 | 07:23 AM
ATLDisco's Avatar
It could also be your IDM. Mine did something very similar, and the cause turned out to be a corroded circuit board in the IDM. Easy fix, cheap too. Apparently its really common with the DII's - so much electronic crap on them.....
- DC
zigzag3141
Apr 13, 2017 12:47 AM
me 2
Nov 3, 2012 03:22 PM
ROVERPIG
Nov 16, 2010 11:59 AM
kumbhani123
Nov 17, 2009 05:36 PM
DivebombInc
Jan 14, 2008 01:09 PM
