Takin my 97 Disco Off-Roadin
Old Mar 27, 2006 | 11:54 PM
Cooper97Disco's Avatar
8th Gear
Default Takin my 97 Disco Off-Roadin
I own a '97 Discovery SD. I have no mods on it and have the stock wheels. I want to take her off-roading. There are lots of rocky trails, mud pools and steep rock hills. Is it alright to take her or are there things that I NEED to get in order to go. Im not worried about cosmetic upsets, just problems under the hood, and suspension problems. Any input would be appreciated.
Old Mar 28, 2006 | 01:58 PM
justfred's Avatar
Default RE: Takin my 97 Disco Off-Roadin
Best way to find out: give it a try! A stock Disco will go over pretty rough stuff. Know when to shift into center diff lock (mainly on really slippery stuff and sand). Keep it S-L-O-W on rocks, keep some momentum in sand and mud. Look twice before you leap (how deep is that pond?). Bring a friend with a ******-em-strap to pull you or them back out.
For me the main mod that I wanted to make but never did, was to replace the plastic piece under the door seals with a "rock rail" so you won't ding up the bottoms of the doors on rocks (my new one has it pre-installed). There are a few places where skid plates would be important if you went over a lot of rocks - steering gear, I believe. After that, raising the car changes all sorts of handling dynamics; I've heard it helps (my '98 was getting a little sloppy in the suspension, especially when on the freeway; I believe many of the suspension fixes help here as well).
Old Mar 28, 2006 | 02:30 PM
JRdisco1's Avatar
yeah just dont go all gung ho redneck and it outta be fine. they were supposedly made for this from the factory
Old Mar 29, 2006 | 11:59 PM
8th Gear
alright thanks. i took it out for a run and it did pretty good. for some reason my four way flashers went on and wouldnt shut off for a while, i dunno what that was about. other than that it was fine. today i noticed it shaking when i go above 75 on highway, possibly some mud caked in underneath?
Old Mar 30, 2006 | 12:03 AM
JRdisco1's Avatar
prolly that and in the wheels
Old Mar 31, 2006 | 07:40 AM
disco12's Avatar
Discos are meant to take a lot My 96 D1 isn't really modded just a Rovertym bumper but I wheeled her and she is a beast. The 3 most important mods you can do is get a winch and some skid plates plus Diff protectors.
Old Apr 2, 2006 | 04:37 AM
8th Gear
what could be wrong with the wheels
Old Apr 3, 2006 | 12:56 AM
mikemeyer0's Avatar
ORIGINAL: Cooper97Disco
the flashers will come on if you hit a bump hard. turn ignition off then restart and they will be off. Also if you hit something real hard it will kick the reset switch for the fuel pump too.
Old Apr 21, 2006 | 03:32 AM
discocolorado03's Avatar
6th Gear
alright bro i have a 95 disco and i go off roading in the creek by school . no problems although i did get in a three wheel action and it wouldent go but i have stock suspension and no lockers but you should be fine just make sure if ur using the four wheel low that it is allthe way enguaged but if needed i would go with a set of two inch spacer and you can move your back coil to the front and put the pair of spacers in the back and have a two inch lift
Old May 26, 2006 | 06:15 PM
NEWtoDISCO's Avatar
8th Gear
ORIGINAL: justfred
what is the center diff lock? is it on 95 discos??? thanks
