taking a long trip and may need help
Old Feb 9, 2011 | 05:19 PM
iownme's Avatar
Default taking a long trip and may need help
hey all....well tomorrow i'm taking the LR from NY to TX. I'm a triple A member but it would be nice if i had a few people on the way with a garage where i could pull into if disaster happened.
The below freezing temps here mean i cannot complete all the things i wanted to get done (as well as all the things i have done) before leaving.
120,000 miles with original HG and driveshaft...not too mention the original water hose with the old style bleeder (sorry mike, soon i promise!)
So the route i'll be taking will be I88 S from binghamton NY then I40 W (Knoxville) to Little Rock, then I30 W to Dallas FW which is the final destination.
Hopefully it will be an uneventful trip. I have plenty of tools and a good jack with me.
Returning to NY in a few days.
Mike....Can i take your phone # with me in case of emergency?
thanks to anyone considering
Old Feb 9, 2011 | 05:53 PM
hilltoppersx's Avatar
fingers crossed for that driveshaft..... good luck man.
Old Feb 9, 2011 | 07:38 PM
Rearden Steel's Avatar
iownme - I am outside Dayton, OH. Not on the way your planning, but if you decide to go west before going south or are not to far out and have an issue, drop me a line. I will PM my info. RS
Old Feb 9, 2011 | 08:56 PM
bosshogt's Avatar
I have an extra T coolant hose fitting and a heated garage to work on your rig. I'm in Indy, IN. You probably will not got this far west before going south west.
Old Feb 9, 2011 | 09:45 PM
frankieoboy's Avatar
Hey Iownme, this is exactly how I feel when I drive far with the truck !!!
Bring along a crank position sensor, some emergency cooling water and your preferred tools just in case.
Enjoy the ride !
Francois
Old Feb 9, 2011 | 09:52 PM
ringerso's Avatar
Safe trip! I've done quite a few long range trips in my Disco, and it's never let me down, hopefully yours will act the same. If, for some reason you happen to find yourself stuck near the middle of North Carolina, PM me, and I'll try and help out.
cheers,
rich
PS. fix that drive shaft!
Old Feb 10, 2011 | 12:08 AM
Eak69's Avatar
Well - 4 months ago I did Chicago to Phoenix in 2 1/2 days with the Rover and a rebuilt engine.
I couldn't tell you what was around me cause I kept staring at the TEMP gauge JUST IN CASE!
Made it though - without really any problems besides putting a quart or two of oil in (had a leaky front crank seal!)
Oh, it cost me like $320-350 in gas too!!!!
Good luck!
Old Feb 10, 2011 | 06:06 AM
iownme's Avatar
thanks to all....i'll update from the road...hoping for nothing to report :+)
Old Feb 10, 2011 | 07:18 AM
sloan74's Avatar
you should get a cheap real time diagnostics tool from the local auto store, one with an LCD etc. just plug it into the OBD-II port and put it on the dash and keep an eye on all your pressures, temps etc. might make the drive a little more relaxing hehe
Old Feb 10, 2011 | 09:05 AM
dcarr1971's Avatar
I'm not familiar with the route you're planning, and don't have a garage, but if you come anywhere near Pittsburgh and have a problem I can try to give you a hand...
