A tale of two Disco IIs (purchase advice)
Newb here looking for a little purchasing advice from the experts. I'm considering purchasing a used Discovery, and have two interesting candidates in mind. They are very similar, and yet very different in one way.
SAME:
Really, they could be twins, except for:
DIFFERENT
In the end, would you pay $1000 difference for the lower miles? I know that should be an easy yes answer, but Disco #1 having had the heads recently done throws the equation a little.
Thoughts??
SAME:
- Both are at a dealer (different dealers)
- Both are 2002 models
- Both are Oslo blue with tan leather
- Both in SE trim
- Both in better than average condition, both exterior and interior
- Tires are identical, even to the point of being worn. Estimate about 75% tread left on both
DIFFERENT
- Disco #1 - 165,000 miles, BUT both head gaskets were done at 145,000
- Disco #2 - 75,000 miles, no service records at all.
- Disco #1 - listed at $4500, I could probably negotiate down to close to $4000
- Disco #2 - listed at $5450, negotiate down to close to $5000
Thoughts??
normally my instinct would be to go with the lower mileage, but this is a LR without any service record it a hell of a gamble, if not fairly mechanical it could be a costly mistake.
Why did the other one have head gasket replaced and how many times did it over heat before the put head gaskets in it? a day or a month?
pre-purchase inspection is the only way
I would do a Pre-purchase inspection on either one, so that's a given. The repair receipt that the dealer has just shows head gasket replacement, does not show reason/symptoms, so no way of knowing if/how bad it overheated.
As for my 4WD/mechanical experience, I would say better than average, but not an expert in all things.
I've never owned a Land Rover before, but have had 4 different 4WD Jeeps (2 CJ-5s, a Wrangler, and a 98 Grand Cherokee) and have done things like replaced driveshaft, axles, transfer cases, etc. Just finished replacing the Viscous Coupling in my Grand Cherokee transfer case. As for overall mechanical ability, I've owned multiple Fiats and a few Triumphs over the years, and kept them all running, so that says something.
Well, this 1s one of the two I'm currently considering -->2002 Land Rover Discovery $5,485 - ARMotorsports.net - Lawrenceville, GA 30046 Dealer
No really looking for any major modifications, it will be a DD for the most part, with the occasional forest road. My heavy duty off-road wheeling days are behind me. I beat the heck out of two CJ-5s back in the day.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Have you already decided you're GOING to get a Disco? There are a lot better choices out there for reliability, gas mileage and can match the off-road abilities. If you just can't imagine driving anything else, welcome to the nut house! Assuming the inspections didn't turn up anything definitive, I'd go with whichever one had the HGs replaced last.
Well, no, I'm not ABSOLUTELY getting a Disco, no matter what. But, if I'm going to replace my current gas guzzling, but extremely capable SUV with something newer/nicer, and maybe a little more upscale, the Disco II seems like it might fit the bill. It's not like my current ride isn't itself a liitle bit of a money pit. It's a 1998 Jeep Grand Cherokee 5.9 Limited. The 5.9 indicates a 5.9 liter V8. That's a 360ci engine that generates 245 HP and gets about 14 mpg. Full-time 4WD system.
Grand Cherokees of this vintage are known for:
Sounds like a lot of what I read on this forum, right?
- leaking various fluids
- electrical gremlins
- horrible mpg
- requiring constant tinkering
- having real off-road capability
- being fairly luxurious
- having owners who alternate between hating them and loving them
Never owned a ZJ, but I've owned an XJ (LOVED it!) and TJ (HATED it!)...both 4.0s & neither was anywhere close to the level of mechanical ownership of the Rover. But I was thinking more along the lines of a 4Runner or FJ Cruiser but I don't know what your wants/needs/budget are or what you'll use it for. Most threads on this subject summarize this way: if you can imagine yourself owning anything else, don't buy one. Having said that, I love mine and there are precious few rigs I would be as happy with (maybe 73-77 Bronco???).
