Tansmission rebuild
I was hoping to see if a could find some info or a step by step PDF on how to rebuild the disco 2 automatic transmission. I tried using the rave PDF and couldn't find any thing in it. Or maybe I'm just not looking in the right stop. Any advice on how to rebuild them please let me know.
Agreed - here's a photo layout on a ZF rebuild, so you would know what you are up against. And the u-pull-da-partz salvage yard near me gets $119 for a tranny, plus $15 core, and gives a 6 month warranty, parts vultures rejoice. Most Discos are in the salvage yard from wreck or head gaskets....
see Chris Cowdery Global Presence
and a BMW manual on same family of transmission
http://smithies.co.nz/land_rover/ZF_...n_overhaul.pdf
I've torn into soome old Chevy th350 and one or two 700r4 and a jeep ax15 Manual. Thanks for the info. The one site didn't make it look to difficult. If anyone know where the best site to get a master kit. Please let me know. The whole reason why I'm doing this is when I bought my disco 2 the owner told me that they drove t around daily for a month or so with a bad prop shaft and when I got to servicing it. It was three quarts low on trans fluid. Now every few days it slips a little and I wanna get to it before I damage it anymore.
Here's a link to one, I have never bought from them. ZF4HP22, ZF4HP24 ZF RWD / AWD trans Transmission Parts Catalog
Here is a exploded view of the tranny - it has an amazing number of parts....
Technical - Repair Manual, ZF4HP22, ZF4HP24 [69400A] - $30.99 : Automatic, Standard Transmission and Transfer Case Rebuild Kits, Cobra Transmission Parts 1-800-293-1848
Dose anyone know if this is a good repair Manual
The factory ZF manual is the best available. It was $114 when I purchased mine in 1987. You are wasting your time thinking about rebuilding yours. I was a transmission builder for 14 years. The ZF is a far cry from the units you listed, and EVERYTHING is critical. Unless you plan to spend another couple hundred on a torque converter you will just be dumping all the left over crap that is stuck in the converter right into your fresh rebuild. Good luck if you decide to gamble.
The best kits are available through Transtar. The problem you will have is the clutch clearances will all be off using aftermarket frictions and steels, and that is extremely important to the calibration of the unit. It will shift like crap and may cause damage. If you venture into the valve body and let the orifice disks fall out you are pretty much screwed as far as ever getting it working properly.
If you fill up the one you have now how does it run? If it's okay when the fluid is full find and fix the leak and drive it.
I've read on the ZF site that this transmission was fitted on many other vehicles. Does it make sense to reuse another kind of vehicle's transmission with the appropriate bell housing, tail cone, fittings and such instead of the exact Disco unit ?
Nope. The unit was introduced in 1984ish. The rest of the auto industry had already implemented electronic control to some extent in the versions they used before the Disco was on the market here. Land Rover stayed with the fully hydraulic controlled unit.
The orifice disks are different for each application, they calibrate the unit to the needs of the vehicle. I don't see this ending well.
Why would you go to all the trouble of hashing together the parts to make it work any way? You can buy a good used unit and be done with it with far less aggravation.
If you were to cobble together a mutt to install you must be sure the spacing is correct for the converter. If not you will destroy the converter, pump, and your day.
