TAPPING NOISE
Old Nov 29, 2008 | 04:37 PM
  #21
DeepBlueWater's Avatar
Default RE: TAPPING NOISE
http://www.youtube.com/watch?v=rfTwiE-D3Gs
I too have a 2003 Disco that develops a ticking noise once in a while.
Does your ticking sound like my post on youtube?
If so it's an easy fix.
MWMG
Old Nov 29, 2008 | 05:33 PM
  #22
Ok, I am intriged, whats the fix?
Old Nov 29, 2008 | 05:49 PM
  #23
AK Rover's Avatar
I'd be curious what the fix is also. Sounds like something that would be good for everyone to know.
Old Nov 29, 2008 | 06:49 PM
  #24
snowdude's Avatar
read the comments of vid, he says just oil additive.
Old Nov 29, 2008 | 09:59 PM
  #25
ATF flush works.
Mobil-1 definitely helps.
Mobil-1 filter likely helps.
My tick comes and goes, mostly goes.
When I hear the tick I simply do an induction cleaning, then I follow it up with a Seafoam crankcase cleaning. And it's gone... meaning in suppression for 25,000ish miles.
My resolve: I simply drain 10oz of oil. Then I replenish it with 10 ounces of Seafoam. I start the engine and let it idol until the ticking stops (usually 30-45 minutes). Seafoam publishes a tech sheet that suggests driveing 100 miles, but I prefer to go the softer route idol+time.
When finished, the oil will drain out like water and the scum that is causing the lifters to stick will be loosened and hopefully drain out with it.
I replinish the oil, replace the filter and it's good. Another oil change at 1,000 miles to expell any residual Seafoam and grime.
Old Nov 29, 2008 | 10:36 PM
  #26
handsome rob's Avatar
I have a 94 that has a similar problem. I have done the ATF, induction cleaning and seafoam in the gas, and still have the tick. In fact the motor ran worse after it all. I have not tried the seafoam in the oil so I might try that next. I actually think that the seafoam in the tank toasted the fuel pump. If that does not work then I am getting the heads rebuilt. Good luck with your solution.
Old Nov 30, 2008 | 08:50 AM
  #27
newdr's Avatar
THAT IS THE TAPPING NOISE.
USING SYNTHETIC OIL KMN FILTER FOR LAST 2 CHANGES. SEA FOAM 10 K AGO. DEALER PULLED OIL PAN, AND CLEANED SLUDGE 10K? AGO.
NOW SITTING IN DEALERS LOT FOR AM SERVICE.
HOW FAR DID YOU DRIVE THE LR WITH THE TAPPING? RISK OF DAMAGE?
Old Nov 30, 2008 | 09:00 AM
  #28
If that is your exact same tapping noise then you have lifter noise, you can drive it like that forever.
These trucks have hydrolic lifters, the only real fix is new lifters.
Keep using the full synthetic motor oil, change it every 5,000 miles and dont worry about it.
If/when you replace your head gaskets do new lifters at that same time.
I had a Chevy that did the exact same thing, thicker motor oil made the lifter noise go away.
My old Ford work van did the same thing too, over 100,000 miles later it still ticked and still ran great.
Old Nov 30, 2008 | 11:02 AM
  #29
sandhonwheels's Avatar
5th Gear
mine is on the same frequency as that but it is coming from underneath and more "tinky". like someone tapping a metal pipe with a hammer. worse when it is cold and not bad when it heats up
Old Nov 30, 2008 | 11:42 AM
  #30
The audio in the youtube post is tinnier than it plays back.
My video camera has a background noise reduction feature that gates ticks, clicks....
