TC, ABS, and brake light just came on
Old Nov 15, 2006 | 04:28 PM
joelxa513's Avatar
8th Gear
Default TC, ABS, and brake light just came on
What is going on with this? All these lights just came on, on the dash. I turn the truck off after I came to a stop, and turned it back on and the only light that stayed on was the ABS light. I have only had this truck for about a month, please tell me this is no big deal. I have already had it in the shop for an exhaust manifold leak, u jionts and the seat frame of the driver seat. It is under manufacturer warranty untill the end of this year, but should I be worried about these things in the future? Thanks for any input you have, Joe
P.S.
If it is the brakes, how hard is it to put new pads on the front of this thing?
I have put pads/shoes on every car and truck I have owned. Do I need special tools?
Old Nov 15, 2006 | 04:38 PM
Default RE: TC, ABS, and brake light just came on
Take it to the dealer, no since worrying about something you can't fix. How many miles do you have on the truck?
Mike
Old Nov 15, 2006 | 04:51 PM
joelxa513's Avatar
8th Gear
It has 44,000 miles on it and they just did the 45,000 service. The brakes make a little bit of noise at stop, but I don't see any irregularities on the surface. If it is the rotors or pads, the dealer doesn't cover this under warranty right?
Old Nov 15, 2006 | 05:59 PM
ORIGINAL: joelxa513
Your right, so go find out for sure, if it is the pads, and since they are squeaking they are probably causing some problem, but if it is something else it will be expensive and you should go to the dealer and at least go get the codes read.
Mike
Old Nov 15, 2006 | 07:29 PM
joelxa513's Avatar
8th Gear
well the seat frame arrives next week and i am going to be dropping it off to have them install it so i will have them take a look at it then. Thanks for all the help! Again, I was wondering if it took any special tools to swap the pads out?
hemicharger69
Dec 13, 2013 04:17 PM
shoei_1411
Nov 29, 2010 07:57 PM
bangkuaidiscovery04
Aug 16, 2010 11:17 AM
operez818
Feb 14, 2009 09:34 AM
