TC light flashed?
Surely it is a loose or wet connection on the transfer case sensor. I can't tell what model you have (I'm on my phone now) . I had to engage mine to test a driveshaft problem a couple of weeks ago, manually, and the light had a mind of its own for a few seconds after engaging and after disengaging. I figured it was the sensor right behind the back of the front driveshaft.
Yes, the TC light turns on when traction control engages. Did the light really remain on for a full 5 seconds, or the duration of the turn? Mine has kicked on a few times making a turn onto a certain road where the roadway is at a different height from the road I am turning from. If one tire is turning a certain percentage faster than the opposing tire, TC will engage. For me, the bump in the turn is enough to sometimes do it.
The TC light flashes up when it is called upon due to road surface conditions. As you may already know it is part of the overall ABS system. Mine kicks in sometimes when turning on the gravel strewn roads around here but as soon as the turn is completed or the TC is not required any longer the light extinguishes.
My mind is sort of un mushed now.
If you weren't on gravel, hitting a bump, or spinning a tire when it happened I would be worried. The traction control system actually counters our limited slip diffs by selectively activating the ABS so the tire with no traction (but all of the power) will give up some of its power to the stalled, slow, slipping tire. If I remember correctly, it was considered by Land Rover to be a good replacement for a locking CDL and locking diffs for typical on road situations. I know this because I have a Ford that has this issue and sometimes as I am stopping one tire will start with the ABS and pull me that direction. It is disconcerting and dangerous. The problem with the Ford is a bad ABS sensor... the ABS sensors also tell the computer how fast the tires are spinning, relative to each other, on our trucks, then it will apply the brake if necessary, and trick the diff into sending power where it is needed. So if you are just ho humming down the road and your ABS kicks in (and there are threads on this forum about that), you can have a very bad day.
