technical brake line question
im having some extended brake hoses made locally and would like to be able to just give them the dimensions and fitting specifications, so that i can avoid removing a line from the vehicle to bring to them.
can anyone tell me the factory lengths of the front and rear lines, and the fitting designations for both ends? i cant find this info via the google box and im getting frustrated. thanks in advance!
The grand idea here is to replace the shocks, brake lines, and abs wires all at once.
But; my friends and I ride sportbikes, have for many years.
We put ss front lines on all of them.
Average cost is $100-$120 from most aftermarket companies.
However, there is a local company that makes hydraulic lines/hoses, whatever you need.
They charge around $60 a pair for the same thing, and make them on the spot. They are around 2 1/2 ' long each too.
You may want to check with heavy equipment services, and/or hydraulic line makers in your area.
Could likely save you quite a bit.
Whenever I can afford +2" springs and 32's, I'll be bringing them my brake lines.
No idea where you are, and what prices are like.
