Temperature gauge
Old Mar 25, 2015 | 09:34 PM
lighting's Avatar
Default Temperature gauge
Looking to install a electric temperature gauge to my 2003 Disco SE, can someone tell where the factory sensor is at and it's safe to just "T" in the same place and run the 2 units or there is better way to do this, thanks.....
Old Mar 25, 2015 | 09:42 PM
robert.juric's Avatar
I've heard great things about UltraGuage for monitoring temperature. I will be picking one up soon.
Old Mar 25, 2015 | 09:49 PM
lighting's Avatar
Thanks but looking to install a hardwired dedicated temp gauge, Ultragauge is excellent but rather have a gauge that I can look at
Old Mar 25, 2015 | 10:15 PM
Robert Booth's Avatar
Here you go
https://landroverforums.com/forum/discovery-ii-18/installing-temp-gauge-2003-disco-ii-33833/
Old Mar 26, 2015 | 03:59 PM
I'm just kind of curious how you would determine if its a better temperature gauge? Is it better placement or higher quality sender?
I was looking and if I were to try this, I'd want to use a gauge like this:
DROK® Fahrenheit °F Panel Thermometer DC 12V Voltmeter Temp/volt Gauge Green LED Digital Electronic Clock 18B20 Probe - Voltage Testers - Amazon.com DROK® Fahrenheit °F Panel Thermometer DC 12V Voltmeter Temp/volt Gauge Green LED Digital Electronic Clock 18B20 Probe - Voltage Testers - Amazon.com
But I wasn't sure what kind of temperature sender would be best to use. If its just a sender quality issue and not the location, would upgrading the sender in its factory location and using UltraGauge to read it be better?
Old Mar 26, 2015 | 07:46 PM
lighting's Avatar
Mr. Booth thank you, exactly what I was looking for. If you ask why don't rely on the Ultra gauge?, simple, a defective sensor or malfunction and you will be looking at a big bill that could be prevented very easy and cheaply. It may have to do with my racing background, always have a second choice when it comes to the health of your engine. Thank you guys.....appreciated
Old Mar 27, 2015 | 11:34 AM
OffroadFrance's Avatar
To date I've never had any issues with either the temp sender or the gauge but with the V8 an aftermarket temp gauge would be a good investment and insurance. Mine is activated by a separate sender located in the top hose in an alloy adaptor and it concurs with the stock gauge. I have a TD5 which is less of an overheating problem than the V8 but I prefer to run an additional gauge as an insurance as overheating in a TD5 is not unheard of. As for the provenance of an aftermarket gauge, well who can tell, whether expensive or cheap all electronics are known to fail. I run a cheapo digitla Dragon gauge (made in China where most electronics come from) and calibrated in celsius (The UK and europe dumped fahrenheit decades ago) and it has visual and audible alarms automatically set. So unless you are really rich the cheapos IMO are just as good as the expensive but are an excellent insurance and cheaper than cylinder heads or HG's. A gauge and kit to install the temp would be circa $30.
IMO there are two gauges that are imperative, a coolant temp gauge and an oil pressure gauge the rest are nice to have but a UG or HUD serves just the same functions but there's nothing like visibility.
Most parts are here:
Mini Speaker TV BOX Wireless Headphone Converter items in TOMTOP Digital Center store on eBay!
Old Mar 27, 2015 | 11:38 AM
drowssap's Avatar
a UG or HUD uses the same sender as the ecu, separate gauge separated sender is always better
Old Mar 27, 2015 | 11:39 AM
Would a sender like this suffice?
Water/Oil/Trans Temperature Sender
I liked the kit posted earlier, but I don't want a big radial gauge, just a small digital gauge, which I haven't been able to find as a kit. So I've been looking for the pieces individually.
Old Mar 27, 2015 | 11:43 AM
x1 totally agree.
