Temperature thread- i think my disco runs hot ;)
Old Jul 1, 2014 | 08:54 AM
dusty1's Avatar
Originally Posted by ls1morethanyou
so the truck got 3500+ worth of damages... lsx swap on the rover?lol nah
i think i got it fixed- or i hope. cleaned out rad, trans cooler/ a/c condenser new fan doesnt wobble at all along with the new rad top cover and treated my self to cup holders and a maf while i was at it.
129 out the door at aaa recycling, i must say not bad at all.
also if anyone is looking for the HUGE two front lights that come on the stock metal bumper their rover has it.
cool.
is that the place in grand prairie?
Old Jul 1, 2014 | 11:58 AM
ls1morethanyou's Avatar
Originally Posted by dusty1
cool.
1797-1817 S Belt Line Rd, Dallas, TX 75253
that's the address to it.
if the truck keeps getting hot and starts to loose coolant might have to ask for your help over a weekend to get the gaskets swapped out.
Old Jul 1, 2014 | 12:25 PM
dusty1's Avatar
thanks.
just give me a shout. I will be around.
Old Jul 1, 2014 | 12:42 PM
Jared9220's Avatar
Yikes!! Head Gaskets all in 1 weekend would be an accomplishment. Good luck with that one. Are you having the new valve seals installed and the heads milled and hot tanked? Don't forget to get new head bolts or upgrade to ARP studs.
How did you fix the wobble in the fan be the way? Just a new fan or did you have to get a new clutch and pump
Old Jul 1, 2014 | 08:38 PM
new to me fan, same fan clutch. I can see a HG job done in a weekend, i have done it before on an lsx car but i also didnt have to send heads in to be milled.
i have the ab head gasket kit. i think ill stick to their bolts since i have them. i just bled the truck for 35 mins, it had some air in the lines hoping this clears up the truck getting warmer at idle, while driving its fine and it hasnt lost any coolant.
Old Jul 2, 2014 | 06:56 AM
drowssap's Avatar
easily done in a weekend if your not held up by the machine shop, I got a set of used heads for $50. for the next time. They can be machined and ready to go on.
Old Jul 2, 2014 | 08:49 AM
Jared9220's Avatar
I'm sure you can get it done in a weekend if you don't have the machine shop to deal with and you really buckle down and don't run into any unforeseen problems. These rovers do tend to throw curve ***** so watch out.
I think I might take longer doing things then your average at home Mechanic. I try and really clean everything and put anything I can fit into the parts cleaner to get cleaned while I have the truck apart and it does tend to really add up in time. Plus with all the Drinking, Smoking, food breaks, and time spent taking pictures for the forum, I can drag a repair out into a fairly long process. I swear I lose all track of time when I fill up the ice chest with beer, turn on some classic rock, and start turning a wrench. I think it's therapeutic to me.
It doesn't matter if it takes you 1 weekend or 1 month, just that you do it the right way the first time.
Old Jul 2, 2014 | 09:28 AM
dusty1's Avatar
yep. cleaning and machining be the time gobblers. otherwise, it's a 1 day deal. 8-10hrs wrenching. I could see the courtesy to photo and document taking a huge chunk too.
Old Jul 2, 2014 | 10:25 AM
here in a few ill be driving to forney for work and will find out what will happen, i will either be starting a HG swap next weekend or a tcase drop.... and the plot thickens. dun dun dun
Discotim369
Oct 4, 2013 05:52 PM
pgk
Aug 31, 2013 05:00 PM
roverguy67
Sep 30, 2012 11:39 AM
kenjisnocon
Jun 16, 2009 06:28 PM
Ann
Jan 25, 2008 05:23 PM
