Tensioner pulley won't turn
Old Nov 15, 2014 | 02:10 PM
Drubie22's Avatar
Default Tensioner pulley won't turn
I just replaced my water pump and t-stat and when I started the disco up I heard a squeal. Turns out that the tensioner pulley isn't turning. Do I just need to loosen it?
Old Nov 15, 2014 | 02:18 PM
dusty1's Avatar
Likely bearing is shot.....
don't loosen the bracket. that wont help.
you can find pretty good deals on pulley kit (includes idlers)
Old Nov 15, 2014 | 04:12 PM
Drubie22's Avatar
Any suggestions on where to begin looking? Also, I should state that when I originally tried to slip the belt off I torqued the tensioner pulley the wrong way... could I have inadvertently tightened it down too much?
Old Nov 15, 2014 | 05:32 PM
dusty1's Avatar
Possible, I guess, that you could have damaged it. I kind of doubt it.local parts store/
Rovers north / lucky 8/ Atlantic British / parts geek / and so on- for tensioner pulley.
I think I got the complete pulley kit through AB but not 100%
Edit: I got this...http://www.roverparts.com/Parts/ERR6439K
Old Nov 17, 2014 | 08:10 AM
CollieRover's Avatar
I have a Gates Belt Tensioner I think I found on ebay. The pulley is metal and really sturdy. I had a Dayco prior to which was plastic, and probably OK, but the Gates feels much more HD.
Old Nov 17, 2014 | 08:57 AM
agthird's Avatar
The dayco is a good one, got it at oreillys.
Old Nov 17, 2014 | 09:53 AM
dusty1's Avatar
I too have had good luck with orielly pulleys
Old Nov 19, 2014 | 06:20 PM
Drubie22's Avatar
Am I looking for a particular size or type that specifically fits '03 Discos?
Old Nov 19, 2014 | 06:49 PM
dusty1's Avatar
I think the tensioner pulley is the same size it is the idler pulley that differ
Old Nov 20, 2014 | 12:37 AM
Rover_Hokie's Avatar
I bought at Dayco tensioner assembly with new pulley at Advance Auto, has worked well for many years now.
