Terrafirma HD Radius Arms
RTE is a doing a custom heavier duty setup, by way of modifying the original rover radius arm.
using a jig table specifically for the size of lift you have; with relief cutting & bending to corrected angle, plating 1/4” steel to both sides fully welded.
You pay core charge, or send RTE your arms.
Simply because the RTE arms are the factory arms, enhanced. I've never had or seen one bend. I have however seen both the equipe and TF arms bend.
