Terrafirma Steering linkage
No, but I need to. I just duck under, make the adjustment, and hope for a different result each time. The definition of insanity.
The adjusting nut just snugs up against the main bar with no locking washer or anything else to keep it in place except friction. I could put some blue loctite on the threads and see what happens. In fact, I WILL.
In fact, now that I think of it I should do that because I have a few more threads in one side than the other and it offends my OCD.
What happened to the OP? HAS THE QUESTION BEEN ANSWERED?
From Rovers North: "Includes solid steel track rod and drag link with steering stabilizer bracket and 4 replaceable tie rod ends with lock nuts instead of clamps. Durable anodized finish."
Pan Hard Rod adjustment - front VS Rear alignment
So...with a 3" TF Lift, would the adjustable pan hard rod really be necessary while the original watts linkage at the back axle is NOT adjustable? Seems you would also need adjustable Watts Linkage if you have a lift, as it would negate the adjustability of the front Panhard Rod would it not?
Or maybe my mind just can't properly see the articulation geometry of Watts linkage, if it also would be affected by the 3" Lift??
the watts linkage under street driving with 3" of lift should still be in an okay position. The watts becomes a limiting factor when trying to articulate the rear with longer shocks and why you can buy an extended link. The way I see it move is that the wheels stay in place (left vs right) as the watts link cycles throughout it's motions. Whereas an non adjustable panhard is too short and pulls the whole front axle to be biased to one side.
I am resurrecting this thread on the Terra Firm TF225 steering rod kit. Terra Firma says their kit has 4 replaceable tie rod ends. Does anyone know where to purchase the tie rod ends? I just can't seem it find it anywhere on the main sources in the US such as Atlantic British, Rovers North, etc. Their sites only list the entire kit for sale.
Thanks in advance.
Thanks in advance.
