Test a coil pack?
Old Sep 12, 2007 | 08:39 AM
crownaviation's Avatar
Default Test a coil pack?
I am trying to figure out an ignition problem which I believe is an alarm issue. Before I go through the trouble I would like to test the coil pack.
Can you test the input voltage at the 4 wire plug that is secured to the intake? If so, what pins should be checked and what is the proper voltage. Not sure why there are 4 wires either..... Thanks for any suggestions!
Old Sep 12, 2007 | 03:16 PM
98roverguy's Avatar
Default RE: Test a coil pack?
http://www.nextag.com/Lisle-LIS19380...27/prices-html
Thats's just one way to do it. There a variety of tools out there that allow you to test the coil. Local shops have em. A tool that connects directly to the coilis the best. That way you eliminate the plug wire. Got light - it's working, no light - dead coil pack (assuming there's nothing wrong upstream).
Old Sep 12, 2007 | 08:19 PM
I was wondering if there was an easy way to test the connector just prior to the coil pack. Evidently there are a few situations where voltage will drop causing the engine to quit. Also, the coils can be individually replaced new at about $90 each thru local parts supplier. Beats the heck out of buying the whole thing.
Currently this is all wishfull thinking as I suspect my alarm ECU is dead. [:@]
Old Sep 13, 2007 | 07:01 PM
dirtyduk's Avatar
I think your barking up the wrong tree here[sm=forgetit.gif]
Old Sep 13, 2007 | 09:24 PM
okdiscoguy's Avatar
ORIGINAL: dirtyduk
How about offering a suggestion on the path he should look down instead of just telling him he is wrong?
Old Sep 13, 2007 | 10:11 PM
He did reply to the other post which is what I think he meant here...Like the truck, I may be wrong!!
Old Sep 14, 2007 | 09:41 AM
okdiscoguy's Avatar
yeah I saw it later...
stormint
Mar 6, 2008 02:24 PM
bamarover
Feb 6, 2008 01:48 PM
jleblanc
Dec 8, 2007 07:56 PM
hendoc3
Jul 19, 2007 06:02 PM
GoldDiscoII
Dec 3, 2006 12:06 PM
