TF Diff Guard fit
Old Nov 7, 2024 | 05:25 PM
dansohner's Avatar
Default TF Diff Guard fit
Hi all,
I think I may be missing something (simple install, right?) but my front diff guard just does not line up no matter what I do.
With the lower guard piece flat against the bottom of the front diff (bolts in, not tight), the top bracket is quite off.
Since I ordered both front and rear at the same time, is it possible that I just got two rear brackets? The pieces that fit on top the diff are the same size - should they be different?
Old Jul 15, 2025 | 05:03 PM
dansohner's Avatar
bump.
Old Jul 16, 2025 | 01:02 AM
rikkd's Avatar
I'd talk to TF. Double check all the parts. I would recommend against TF diff guards. I've gone through 2, both of which failed on easy trails. I had one get pulled out by a stick, and the other got bent and deformed after hitting rock at like 2mph.
Old Jul 16, 2025 | 12:27 PM
keninnc's Avatar
You are not wrong. I installed these about a year ago and the fit is not good.
Both my top brackets were the same as well.
I had to take a screwdriver and insert them into the slot and hole and pull them together to get the bolts in.
Very frustrating, should be a 15 minute install and ends up an hour under your truck.
Old Jul 17, 2025 | 01:05 AM
acg's Avatar
acg
Ditto here. I have a couple of incidents where the mounting bolt area got sheared off from light hits on rocks. I ended up switching to the Rovers North ones (much beefier).
Rover_Hokie
May 15, 2017 05:35 PM
Rover_Hokie
May 14, 2017 06:42 PM
bosshogt
Apr 21, 2013 01:22 PM
JamesDisco97
Jun 15, 2012 05:14 PM
bosshogt
Feb 27, 2011 06:32 PM
