Thanks for the info
Old Jun 1, 2015 | 03:56 PM
gulfstream69xr7's Avatar
Default Thanks for the info
A couple of weeks ago I got the 1412-1415 engine code after having some work done on my Discovery II.
The mechanic who did the work could not figure out what the problem was. The SAI pump and the Solenoid checked out fine.
After searching this forum I decided to check all of the vacuum lines and connections. Turns out that the line from the vacuum canister to the SAI solenoid was cracked inside of the plastic line cover.
I replaced all of the associated vacuum lines, reset the codes, and all is good.
Learned everything I needed to know to track this down from this forum.
Thanks!
Old Jun 1, 2015 | 10:31 PM
Rover_Hokie's Avatar
Knowledge is power! Rover on!
BeerRoving
Jan 10, 2010 08:10 PM
sjviva
Nov 2, 2009 07:22 PM
84 GRANDSPORT
Feb 16, 2007 08:08 PM
JVG1999
Mar 11, 2006 06:34 AM
disco12
Jan 31, 2006 12:17 AM
