Thechnical Bulletin
Old Nov 9, 2009 | 10:18 AM
coldfrez's Avatar
Question Thechnical Bulletin
has any one ever heard of "Technical Bulletin 70-01-05NAS"???
I tried to get info online but got nothing. Can someone advise what it was for. From what i understand it has to do something with the ABS sensors.
Old Nov 9, 2009 | 10:21 AM
bearcatfans's Avatar
No: 70/01/05/NAS
FGN LT206-09
Replaces: 86/04/04/NAS
Issue: 1
Date: 07 July 2005
ABS Sensor Overlay Harness
AFFECTED VEHICLE RANGE:
Discovery Series II (LT)
All
SITUATION:
ABS WIRING HARNESS DAMAGE
Environmental influences or mechanical damage can result in wiring harness malfunction. The ABS harness is exposed to hostile elements that can result in open circuits or other wiring-related ABS symptoms.
RESOLUTION:
USE SERVICE "OVERLAY" HARNESS TO REPAIR ABS ELECTRICS
New ABS "overlay harness kits" have been made available for service repairs. The harness deletes the front connectors located in the front fender wells in production vehicles. The harnesses MUST be used instead of replacing the main or chassis harness for ABS sensor harness concerns such as open circuit conditions.
PARTS INFORMATION:
Old Nov 9, 2009 | 10:22 AM
I have the whole TSB. PM me if you need it. It's rather lengthy.
Old Nov 9, 2009 | 10:35 AM
Good feed back, tyhat explains why the newer replacement speed sensors have been coming out with the longer harness that has to be hard wired into the Slabbs.
Old Nov 9, 2009 | 01:28 PM
I knew the new ABS sensors had to be hard wired but never knew why.
Drknite
Freelander
Aug 17, 2010 06:17 AM
