Is there a new link to the Option B procedure steps?
Old Mar 1, 2025 | 12:06 AM
Brandon318's Avatar
Default Is there a new link to the Option B procedure steps?
The old Weebly link is NLA and I finally got the shuttle valve ABS code today.
Old Mar 1, 2025 | 01:11 AM
Windycity_rover's Avatar
Try this https://drive.google.com/file/d/1CA4...ew?usp=sharing
If it doesn't work I'll email it to you.
Old Mar 1, 2025 | 01:23 AM
This is better
Old Mar 1, 2025 | 08:57 AM
Brandon318's Avatar
Originally Posted by Windycity_rover
This is better
Hero, thanks!
Old Mar 1, 2025 | 10:02 AM
Best4x4's Avatar
Option B in a nutshell:
Lift ABS Modulator up out of it's mounting bracket
Remove 3 Allen Headed Bolts (highly recommend a GOOD Allen)
Unplug old Shuttle Valve Switch Assembly
Either repair or replace SVS Assembly with pigtail now attached
Install SVS with pigtail coming out the bottom (DO NOT LEAVE OLD PLUG)
Cut the yellow/green wire about 4inches back from connector
Connect one side of SVS pigtail to vehicle side yellow/green wire
Connect other wire from SVS to ground.
View & clear ABS faults with scantool able to view LR ABS codes
Upon startup you should just have a single ABS light
Drive vehicle & within 50yd or so ABS light should go out
Old Mar 1, 2025 | 10:20 AM
Brandon318's Avatar
Noted, thanks! And for running the pigtail out of the SVS, just drill a hole?
Old Mar 1, 2025 | 10:33 AM
Best4x4's Avatar
There are 2 holes I route the wire thru but you can drill new ones if you prefer.
Old Mar 1, 2025 | 10:39 AM
Drill a hole.
me 2
Sep 14, 2021 10:22 AM
Tomzsix
Feb 2, 2021 01:29 PM
EAustin494
May 26, 2019 12:26 AM
Mando
May 13, 2017 07:32 PM
Friday Night Disco
Feb 4, 2017 06:05 PM
