Is there seat trim on the inboard side of the front seats?
Old Sep 5, 2019 | 03:24 PM
Brandon318's Avatar
Default Is there seat trim on the inboard side of the front seats?
Mine only have trim on the outside part of the lower cushions. The inside part (the part that faces the transmission tunnel) look pretty unfinished. Is that correct or is there supposed to be something there?
Old Mar 26, 2020 | 06:40 PM
Extinct's Avatar
Spend your time on reliability upgrades, wrong vehicle for performance improvements. Key pm work:
1. Sunroof leak issues - search my post - prevents headliner issues.
2. Coat CPS cover with aluminum foil to prevent CPS failure.
3. Remove door panels and lubricate window regulators to prevent common failures.
4. Lubricate cargo door handle to prevent rust seizing
5. PCV mod to prevent oil leaks
6. Inline thermostat mod to prevent overheating
7. Replace all original cooling system plastic or rubber components to prevent overheating and head gasket job
8. Lubricate door straps to prevent popping
9. Coat rear frame to prevent rust
10. Remove and coat cowl panel with bedliner spray to prevent UV cracking
11. Wax exterior to prevent clearcoat fading
12. Lube front driveshaft and/or replace u-joint to prevent failure
13. Replace shifter boots - make your own with leather and superglue
14. Check idler bearings for wear and replace if necessary
15. Sand and recoat fender flares with bedliner.
Have fun!
Old Mar 26, 2020 | 06:59 PM
mr. choodles's Avatar
Brandon, there is nothing there. Each seat has plastic lower trim on 2 sides: front and the side that is facing the door. I just finished wiring, lower body review. After all of that work, I am contemplating removal of those panels.
Old Mar 26, 2020 | 08:29 PM
ahab's Avatar
That's a great list Extinct and I have printed it as a holy grail of preventative maintenance items. However, I think you meant to post it to this thread.
https://landroverforums.com/forum/di...ng-buck-99551/
Old Mar 26, 2020 | 08:35 PM
Brandon318's Avatar
Post resurrected haha! Well, some obligatory follow-up. Yes, the trim was missing but found the pieces from a donor disco. These were the trims bits I was referring to.
Old Mar 26, 2020 | 08:44 PM
ahab's Avatar
Good follow up. Those would be called hinge covers. My truck was missing the passenger side as well. I got a new one from the dealer and it snaps on half-heartedly, and then falls off whenever it wants to. Frustrating.
Old Mar 27, 2020 | 01:51 AM
Extinct's Avatar
Fixed! Thanks. Too much Rona drinking
xhevi
Jan 17, 2019 01:31 PM
Eu4x4engimports@gmail.com
Apr 11, 2016 10:12 AM
goatman
Jan 12, 2013 10:08 AM
KimPeter
Apr 26, 2012 03:26 PM
paul1454
Apr 14, 2011 04:04 PM
