Are there two types of transfer cases for the 03-04 D2 with the 4.6?
Do not try to lift the t-case. It's too heavy to manipulate accurately and you need to be careful when you slide it onto the transmission output spline. You need a transmission jack for sure.
I swapped mine without a lift. Just put the truck on some ramps. If you use a lift, you'll have to work out how to get the tranny jack up high enough to use it, plus you need to be able to get in and out of the cab to do stuff inside as well as underneath.
I know I'm reviving an old post, but I can't find relevant information on the topic of NV225 transfer cases. I just acquired a 2002 P38. The tranny was run without fluid and burnt up the wiring harness. While removing the T-case, we took the case apart to inspect the chain. It can move up and down about 3/4". It seems about border line needing to replace. I was looking for a new chain and found the STC3238 chain and also the HV-083 chain. The HV-083 is listed for the 03-05 NV225. Based on the conversation above, it seems like there are differences that may not affect the drive chain. The HV-083 is ~$80 while the STC3238 is ~$650. Does anyone know if the HV-083 will fit on the older 98-02 NV225?
cornbreadj
Apr 5, 2015 09:20 PM
