Thermostat/radiator
Old Apr 25, 2010 | 04:13 PM
kjordan's Avatar
Default Thermostat/radiator
Ok guys, I have a small puddle of coolant under my radiator and a little bit of coolant on the ground. Was trying to track down the leak and had it running for a bit to see if I could see it. Then I realized that my lower radiator hose was cool while all other hoses were hot. Is this a thermostat issue? It was replaced two years ago, is that a normal life span or do I have a bigger problem?
Thanks
Old Apr 25, 2010 | 04:39 PM
Willie00d2's Avatar
Was it running long enough to get up to temperature?
Willie
Old Apr 25, 2010 | 04:47 PM
Sounds like 2 separate issues, a leak and possible flow issue.
Old Apr 25, 2010 | 05:06 PM
kjordan's Avatar
It was definitely up to temperature.
Old Apr 25, 2010 | 05:45 PM
Willie00d2's Avatar
For the leak, check the two screw holes that go into the top of the radiator that holds on the fan shroud. I had these leak before, sealant works for a while on these.
Willie
Old Apr 25, 2010 | 09:11 PM
kjordan's Avatar
So should I change the thermostat or am I wrong on that assumption? I realize I might have two issues but where do I start?
Old Apr 26, 2010 | 01:58 PM
kjordan's Avatar
Anyone...Bueller...
Old Apr 26, 2010 | 09:43 PM
kjordan's Avatar
Wow, so no one has any input... Let me ask one more question. Should the lower radiator hose be cool/cold while the others are warm/hot?
Old Mar 7, 2013 | 09:16 AM
Mojigglins's Avatar
I have the lower rad hose problem too. I have replaced the t-stat (190*) and flushed the system, still the lower rad hose is cold. The temp runs up to 215, then 210 when the electric fan kicks in at idle and around 206 while driving (kind of stop and go, I only have 3 stop lights in my town) I should have tested the t-stat before installing it. I should get my 180* t-stat any day now. If there is no change in temps and lower rad hose is still cold I will be convinced that my rad is clogged.
My Tip of the day is to replace all of those stupid hose clamps with the ones you can tighten and loosen with a screw driver of socket. It really saves you knuckles and sanity!!!!!!
Old Mar 7, 2013 | 09:32 AM
clanch's Avatar
Remember stock thermostat will by-pass to the heater core at idle. Order a soft spring 82 cell thermostat first. It start give flow to the radiator even at idle, and will open early. If radiator has never been change, replace it, old and plugged.
