Thinking about making my Nanocom available for rent ¯\_(ツ)_/¯
Old Nov 20, 2019 | 10:26 PM
  #41
mln01's Avatar
And so can a Hawkeye.
Old Jan 26, 2020 | 08:34 PM
  #42
eitydeuce's Avatar
Hello Brandon, Is the Nanocom available? I'm interested in renting it so I can do a couple of things with it. I need to program a new fob and troubleshoot a SRS light I have had on since I bought it.
Old Jan 26, 2020 | 09:43 PM
  #43
Brandon318's Avatar
It is indeed! Another forum member just wrapped up with it and it should be arriving tomorrow morning. I can get it out to you tomorrow afternoon or Tuesday. When/if ever you're interested in it, go ahead and fill out the google form and I'll get everything over to you.
Old Jan 26, 2020 | 10:14 PM
  #44
eitydeuce's Avatar
Ok thanks, I’m still waiting on my new fob to arrive in the mail so if you don’t mind I’ll reach out when I have it. Thanks!
Old Jan 26, 2020 | 10:41 PM
  #45
Brandon318's Avatar
Sounds good!
Old Feb 9, 2020 | 09:24 AM
  #46
JackSprw1776's Avatar
3rd Gear
Default Like to Borrow Nanocom
Sixpack577, I’m in VB and would like to see logistics of using your Nanocom, if it applies to my 1997 Disco 1.
Old Feb 9, 2020 | 09:34 AM
  #47
Sixpack577's Avatar
I have a D2, and don't know if and what a Nanocom could do on a D1.
I am also 4 1/2 hours west of Va Beach.
Old Feb 9, 2020 | 10:07 AM
  #48
3rd Gear
Default Checking if D2 Nanocom works on D1
Thanks Sixpack, I will check now with Blackbox Nanocom and see if they recommend the D2 Nanocom for both series. Might be a second generation revision thing, I hope 🙏
Old Feb 9, 2020 | 10:26 AM
  #49
Brandon318's Avatar
Discovery 1s use an engine management system called GEMS, D2s for the most part use Motoronic (Bosch). The nanocom won't work at all across the models, but even moreso since the majority of D2 Nanocoms will be ordered for Motronic motors, not GEMS.
Old Feb 10, 2020 | 10:26 AM
  #50
3rd Gear
I just received the following reply from Nanocom
Discovery 1 is not covered by Nanocom Evolution.
So, I have a large Discovery 1 as a paperweight?
Any thoughts, ways around this? I have seen a jumper to bypass the Spider advertised on eBay, but other than that I am looking at jumpering around these Immobilizer and Theft boxes. Inputs?
JackSprw
