Thinking about making my Nanocom available for rent ¯\_(ツ)_/¯
Old 02-10-2020, 12:29 PM
Brandon318's Avatar
Originally Posted by JackSprw1776
I just received the following reply from Nanocom
Discovery 1 is not covered by Nanocom Evolution.
So, I have a large Discovery 1 as a paperweight?
Any thoughts, ways around this? I have seen a jumper to bypass the Spider advertised on eBay, but other than that I am looking at jumpering around these Immobilizer and Theft boxes. Inputs?
JackSprw
Zero clue. Might be better suited for the D1 forum.
  #52
Old 03-02-2020, 10:19 AM
tnkeith's Avatar
2 Questions -----
1) What do I need to purchase to program 2 new keys? I have a "fob" portion that the key blank is broken out of, that (I think) still works; and I have a key with no electronic guts, which is the one I use. I have been just manually locking the doors with the key.
2) Any possibility the Nanocom can aid in learning what the heck is causing my 3 amigos??? (I have a Foxwell 520)
  #53
Old 03-02-2020, 11:02 AM
Brandon318's Avatar
Originally Posted by tnkeith
2 Questions -----
1. You need a brain (the control unit) either new or from a used key. A great source are junk yards or disco part outs. And you need a new key shell to put the brain in from the donor key. Atlantic British is the best source for these. For $2, any key shop can cut a new one for you. Once you have those two things, the Nanocom will pair up the key and the disco.
2. It can, it did with mine. It has a module that displays SLABS fault codes in relatively plain English. I had an issue and it pointed to the right front wheel speed sensor being the culprit.
  #54
Old 03-16-2020, 04:39 PM
Erica Nichols's Avatar
I am selling a like new Nanocom TD5 for $75 + shipping if anyone is interested.
  #55
Old 12-22-2021, 06:31 AM
brivalen's Avatar
Nanocom rental still happening? In Pittsburgh and would like to try it out and turn on my DRL.
  #56
Old 12-22-2021, 06:58 AM
cds72911's Avatar
Default Rental
If this is still a thing, I'm also interested in a rental to disable Superlock and program a key remote fob.
We picked up a 2001 Discovery 2 for my son and are baselining it. The superlock and fob are not things that would push me over the edge to buy a Nanocom for $400+, but renting it for a day would be great.
In the meantime, I'll depin the superlock wire on the door lock actuator harness as I repair or replace them. That'll prevent lockout, but not help with disabling the ecu, so he could still be stranded.
  #57
Old 12-22-2021, 07:25 AM
whowa004's Avatar
Not a thing anymore. People weren't taking care of it and the unit was getting unnecessary wear and tear so Brandon quit renting it out. Hard to blame him.
cds72911 (12-22-2021)
  #58
Old 12-22-2021, 08:28 AM
mollusc's Avatar
The cheaper Hawkeye will disable superlock and enable DRL (but you'll need to get the resistor pack as well).
  #59
Old 12-22-2021, 08:30 AM
mln01's Avatar
Where are you located?
  #60
Old 12-22-2021, 08:46 AM
cds72911's Avatar
I live in the Burlington, Vermont USA area (Charlotte, VT).
Quick Reply: Thinking about making my Nanocom available for rent ¯\_(ツ)_/¯
