Three Amigo Problem
Old Oct 10, 2007 | 08:15 PM
ajh's Avatar
ajh
Default Three Amigo Problem
So, while on about a 45 degree angle, sliders deep in mud with the tail pipe in the water and winching out (off nothing solid) I had the three amigos come on. This was very bad since my front is a TrueTrac and this basically made it work like an open-diff again.
They have stayed on, any ideas on what to look for? I made sure none of the plugs pulled on the ABS sensors but it's dark and things are mud-encrusted so it's a bit hard to see if the sensor cables themselves have been compromised.
Ideas?
Old Oct 10, 2007 | 10:04 PM
okdiscoguy's Avatar
Default RE: Three Amigo Problem
Dude, you need to invest in an Autologic scanner.......I'll bet one of the wheel sensors got dirty.
Old Oct 10, 2007 | 10:14 PM
ajh's Avatar
ajh
I'm looking for a scanner now, suggestions and advice is appreciated. I guess I'll pull things apart and clean them, what a pain though. You'd expect those to be water tight.
Old Oct 11, 2007 | 10:15 AM
$8000 give or take.
As for the cause, either a sensor got dirty or simple because the wheels were spinning at different rates while trying to get out and possibly braking, either would throw a fault.
I don't understand why you felt this would cause a problem with your T.T., ABS has no effect of these lockers. I run a T.T. in the front and a Detroit in the rear and as long as I have the CDL engaged, it doesn't matter what is going on the T.T. works.
Old Oct 11, 2007 | 11:08 AM
ajh's Avatar
ajh
Yeah, I'll pull and clean them today and put a touch of silicone on the fitting when I re-fit, same with the plug connections.
Yeah I thought a TT should, but I may have had too little pressure on that wheel then because my left front certainly stopped spinning.
I'll have to pull the photos and post them. It was 'need a Challenger II' stuck.
Old Oct 11, 2007 | 11:18 AM
Don't put any lube of any type on your sensors, it will with time get down on to the head of the sensor, collect dust and throw codes.
Old Oct 11, 2007 | 01:55 PM
ajh's Avatar
ajh
I didn't mean lube, I meant waterproofing but it's a moot point I found a tear in one of the sensor wires and have spliced it but can't get it reset until tomorrow morning.
Thanks for the advice.
Old Oct 11, 2007 | 02:19 PM
okdiscoguy's Avatar
ORIGINAL: ajh
You need to start putting up videos on YouTube...or go to work for LR's R&D department....
Old Oct 11, 2007 | 02:46 PM
ajh's Avatar
ajh
No kidding. I got so deep into Mountain/Rock/Ice climbing that I had to start a guide service just to write off the gear and justify more
I will post some pics soon, just need to pull them off the camera.
Old Oct 12, 2007 | 09:02 AM
ajh's Avatar
ajh
Well looks like the short in the torn (and now repaired) line was the problem resetting the codes all is fine. Now to go get some nylon wire wrap and armour up those cables a bit.
04BluDisco
Jan 23, 2010 04:24 PM
kallgrer
Jan 14, 2010 08:54 AM
silver06hemic
Jan 2, 2009 03:51 PM
Dino76
Feb 12, 2008 03:03 PM
lrblack12
Aug 22, 2007 02:35 PM
