Three Amigos — Time to deal...
Old Mar 8, 2019 | 03:28 AM
Fallstaff's Avatar
Default Three Amigos — Time to deal...
I've been ignoring the Amigos for too long now. Time to deal with them.
I had to get $1000 of brake work done just to get the brakes up to scratch - rotors, pads, stuck callipers... that kind of thing. Turns out I just don't drive her enough for outdoor storage. I'll try to learn from that...
My cheap ELM wifi reader can't see any codes.
But I had a shop pull these codes (and I quote):
  • 135 Engine Speed Input signal dubious
  • 134 Shuttle Valve Switch electrical failure
  • 76 ECU Ground or Reference ground fault
  • 73 ECU Internal valve relay fault.
I haven't a clue where to begin.
Wondering about "Option B" from here:
https://landroverclubvi.weebly.com/abs-mod.html
Looking for advice from the group. Thanks in advance.
Old Mar 8, 2019 | 09:04 AM
Best4x4's Avatar
Option B should certainly be done. It’s cheap, very easy to do, and fixes the known bug inside the Wabco Unit. Then you should get yourself a scantool that can read LR ABS faults (makes your life a breeze trust me), and after Option B it should just be an ABS sensor issue which also isn’t hard.
Old Mar 8, 2019 | 09:56 AM
CollieRover's Avatar
I'm with Best. Start with Option B, and go from there.
Old Mar 8, 2019 | 03:08 PM
Fallstaff's Avatar
Alright, I suppose that's the best corse of action. Sure with it wasn't wintering out so much...
I do have one other suspicion — one of my wheel hubs came with a severed cable that I very carefully fixed (was not worth shipping back to the UK). But snow, salt and ice... I suspect I should open it up and see what state it's in.
Thanks guys!
Old Mar 8, 2019 | 03:41 PM
Best4x4's Avatar
Use some 3M heatshrink butt splices & cover with another layer of heatshrink = ABS sensor connection will be good to go.
Old Mar 8, 2019 | 07:43 PM
merebel's Avatar
Option B fixed mine and no more issues and I had the ground issue too and it was a pain to find and fix.
What I found was loose grounds in the left and right kick panel area to be loose and drivers side was missing the 10mm nut and not connected at all.
once that addressed all has been great
Old Mar 9, 2019 | 07:14 AM
mln01's Avatar
I do have one other suspicion — one of my wheel hubs came with a severed cable that I very carefully fixed (was not worth shipping back to the UK). But snow, salt and ice... I suspect I should open it up and see what state it's in. Thanks guys!
You aren't getting any wheel speed sensor codes so your severed cable fix isn't the problem. As others have said, start with Option B and go from there, next chasing and checking the grounds.
Old Mar 9, 2019 | 09:08 AM
Fallstaff's Avatar
Good point on the wheel sensor.
Is there a list somewhere (in the rave?) of all the ground points?
and is there a logical way to check a ground with a multimeter, or is it it just, inspect, clean and tighten?
Old Mar 9, 2019 | 09:44 AM
Best4x4's Avatar
Most likely the wiring inside the Shuttle Valve Switch assembly is all cracked and causing ground faults. I personally install a new Shuttle Valve switch assembly whenever I do Option B so I won't have to mess with it for a very very very long time. However if the Shuttle Valve Switches test good (they usually do) then just cut off as much of the bad cracked wiring as possible and using a 3M Butt Splice connector then add the 2 wire trailer type plug harness and run it out the bottom of the Switch assembly.
Old Mar 11, 2019 | 03:26 PM
Fallstaff's Avatar
Hmmm... just tried to take a look at grounds. Other that the ones around the main fuse box, I haven't the first clue where to look. Thought it would be the kind of thing I could work out, but... Had a look around under the passenger and drive compartments. Sure are a lot of wires...
Might be because it's winter and my patience is limited.
If anyone has shots or hints of where the grounds are, that would be helpful.
