Three Amigos — Time to deal...
Old 04-05-2019 | 05:22 AM
JUKE179r's Avatar
Thanks for the pics!
  #22
Old 04-05-2019 | 03:09 PM
Fallstaff's Avatar
F%&K ME!!!!
Why is nothing easy?!?!
Everything going back together all clockwork, doing up the three underside screws. Then the unit falls off the bit off wood it's sitting on and bangs this little bugger and it snaps off.
I assume that means I just killed the whole unit. Am I right?
And the what gets me. I could have put the front back on before I did the bottom bit. Then it would have been fine. But I was reversing the uninstall...
  #23
Old 04-05-2019 | 03:20 PM
Fallstaff's Avatar
It's a 2 to 3 thousand dollar part.
I just killed my truck didn't I? Son of a b...
  #24
Old 04-05-2019 | 04:21 PM
Red5's Avatar
I don't know what that plunger does, but if it's plastic, it probably doesn't see super high pressure. And if you compare the location to the shuttle valve assembly, it doesn't look like they actually "do" anything during normal operation. Looks like they live here...
Pump the brakes and see if you're losing any fluid. If not, you may be ok.
Or you could lose the pedal randomly and crash into a busload of nuns, so be careful. In fact, if that happens, I specifically said that you would NOT be ok. For the record.
  #25
Old 04-05-2019 | 04:37 PM
Fallstaff's Avatar
Not plastic. Steel. Hard steel (hence its ability to snap so easily). Holds spring pressure against something or other.
But thank you, and the nuns thank you.
  #26
Old 04-05-2019 | 04:43 PM
Fallstaff's Avatar
Hmmm.
When it’s assembled that spring is tight against the front plate. Is there a chance that’s just there to locate and hold the spring during assembly?!,
That I could work with.
  #27
Old 04-05-2019 | 04:44 PM
Best4x4's Avatar
I never remove the front assembly for Option B Install. Should be able to pull that part from a junk yard cheap.
  #28
Old 04-05-2019 | 04:45 PM
Fallstaff's Avatar
Unless it stops whatever is inside that hole from going in deeper... unfortunately it’s a bit of a magic box to me. No real idea what’s going on in there.
  #29
Old 04-05-2019 | 04:50 PM
Fallstaff's Avatar
Belay that! You are right, it is plastic. I just perceived it wrong.
I think it might just be a spring locator. That would be wonderful.
  #30
Old 04-05-2019 | 08:32 PM
DavidOHendo's Avatar
Banned
Did a shuttle valve fix .. I want to buy a new WABCO unit .. but I'll be dammed if I'm spending $3,000 on that part .. especially when they don't have a guarantee it won't come back ..
Quick Reply: Three Amigos — Time to deal...
