threw 2 CEL codes. any help?
Old May 25, 2007 | 12:15 PM
97DiscoKid's Avatar
6th Gear
Default threw 2 CEL codes. any help?
the two codes are p0158 (O2 sensor i think) and a double p1193 that said manifacturer something and some other fault. could the oxygen sensor be causing the other two codes? and where can i get the sensor for bank two sensor 2?
Old May 25, 2007 | 03:31 PM
Default RE: threw 2 CEL codes. any help?
P1193 Oxygen Sensor Heater Circuit Open Downstream , P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2) . What year and how many miles on your truck?
Mike
Old May 26, 2007 | 09:50 AM
97DiscoKid's Avatar
6th Gear
There are 104k miles on the truck and it's a 97.
Old May 26, 2007 | 10:07 AM
With that mileage your 02's are getting tired, time to replace all 4 02's for starters, then make sure your plugs and wires are in good shape.
Mike
Old May 30, 2007 | 04:07 AM
kylle08's Avatar
I agree with the above posts. Its time to replace your land-rover oxygen sensor with a new one. I had mine replaced at 100k miles and its now working great. It is also good to check on your spark plugs and see to it that it isn't worn out. or it would be best to have your car tune-up..
Joshman
Mar 3, 2014 11:30 PM
jhill15
Feb 11, 2013 01:54 PM
UpChuck
Jan 31, 2011 10:31 PM
tigertrakstar1
May 21, 2010 03:31 PM
Disco2Guy
Mar 16, 2008 08:40 AM
