Throttle Body Coolant Hoses
Old Mar 17, 2010 | 10:54 PM
ChanchoVerde's Avatar
Default Throttle Body Coolant Hoses
Getting ready to attach the two coolant hoses to the throttle body. One hose is short and all rubber. The other is a long hard plastic line that extends from the expansion tank to the throttle body.
My question: If your standing in front of the Disco looking towards the engine, which coolant hose goes on the left side and which on the right? Does it make a difference?
Thanks for your help.
Old Mar 17, 2010 | 11:03 PM
Frank4's Avatar
It does not make a difference but I think the hose that comes from the intake manifold goes on the left. Are you replacing the heater plate gasket? If you are bypass it!! That is unless you like performing that repair over and over. That component is a horrible weak link in the cooling system.
I always get slammed for this advice but it motivates me.
Old Mar 18, 2010 | 01:19 PM
Thanks for the advice Frank.
Old Mar 18, 2010 | 01:52 PM
Shane83's Avatar
Personally, I like the advice, it worked for me and yes, it is a VERY weak link in the cooling system!! Much as the drive shaft is for the running train!
Just my 2 cents!!
Good day fellas...
Old Mar 19, 2010 | 09:53 AM
okdiscoguy's Avatar
Just don't run on a freezing Highway for very long.
Old Mar 19, 2010 | 10:31 AM
Danny Lee 97 Disco's Avatar
Guys,
What be this Heater Plate, not familar with the system. Is it the same on a DI?
Old Mar 19, 2010 | 11:07 AM
Shane83's Avatar
The one that runs from the coolant tank goes on the right hand side if you are looking are at the engine from the front!
best of luck my friend,
Old Mar 19, 2010 | 12:10 PM
Thanks for the info Shane. I took pictures before breaking the engine down but something was in the way and I couldn't tell which hose went where.
Anyway, thanks man.
Old Mar 19, 2010 | 12:29 PM
okdiscoguy's Avatar
Originally Posted by Danny Lee 97 Disco
Guys,
Similar on a D1. Not as problematic. The 2 little coolant lines running to it should be checked, but the heater doesn't leak like a D2.
SenatorPerry
Jul 15, 2013 10:28 AM
CANAMDiscovery
Apr 24, 2012 07:19 AM
adwarren78
Mar 7, 2009 05:15 PM
RamblingMan
Mar 2, 2009 10:39 PM
david1289
Oct 28, 2008 12:24 PM
