Throttle-Body Heater Gasket
When I did it I was doing my head gaskets so I had the upper intake manifold off so it was super easy. I'm not sure if you have to remove the upper IM or not I guess it depends if you can get to the little bolts or not. But the part itself is only 4 bolts and 2 hoses to install.
Super easy to do, maybe 30-45min. When I did mine I just pulled the intake off the Throttle body and removed the throttle body, and of course the hoses, etc. Flipped er upside down and got to it. I think it prob could have been done without removing the throttle body but for as little of a pain as it was I thought it was worth it to be able to put it on the bench to work on.
KernowDiscovery
Dec 10, 2013 07:22 PM
